I am currently using port 8 to power my skimmer. I am using the single ATO function for top ups...
I am using the high ato float switch to turn off my skimmer if ther sump water level rises.
The problem I am experiencing is that port 8 relay which my skimmer is connected to, switched on and off for a split second ever few seconds.
Sometimes even port 6 which is fo rmy ato pump switched on and off quickly...not sure whats happening
Below is my code...hope someone can point out where the problem is or is it a faulty relay box?
ReefAngel.AddPHExpansion(); // pH Expansion Module
ReefAngel.FeedingModePorts = Port6Bit | Port7Bit | Port8Bit;
ReefAngel.WaterChangePorts = Port7Bit | Port8Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit;
ReefAngel.StandardLights( Port1,6,45,19,15 );
ReefAngel.StandardLights( Port2,11,45,17,30 );
ReefAngel.StandardHeater( Port3,240,255 );
ReefAngel.StandardHeater( Port4,240,255 );
ReefAngel.StandardFan( Port5,260,265 );
ReefAngel.CO2Control( Port7,650,660 );
static unsigned long atoTimer;
if (ReefAngel.DisplayedMenu==FEEDING_MODE) atoTimer=now();
if (now()-atoTimer < 300) { //300 second delay (five minutes)
ReefAngel.Relay.Off(Port6);
} else {
ReefAngel.SingleATO( true,Port6,20,0 );
if (hour()>=7 && hour()<10)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,80,5,true) ); // Ramp from 0% to 80% with 5 second duration in antisync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,80,5,false) );
if (hour()>=10 && hour()<17)
ReefAngel.PWM.SetDaylight( ElseMode(80,20,true) ); // ReefCrest at 80% +/- 20% on antisync mode
ReefAngel.PWM.SetActinic( ElseMode(80,20,false) );
else if (hour()>=17 && hour()<20)
ReefAngel.PWM.SetDaylight( LongPulseMode(0,80,10,true) ); // Ramp from 0% to 80% with 10 second duration in antisync mode
ReefAngel.PWM.SetActinic( LongPulseMode(0,80,10,false) );
else if (hour()>=20 || hour()<7)
ReefAngel.PWM.SetDaylight( ElseMode(30,10,true) ); // ReefCrest at 80% +/- 20% on antisync mode
ReefAngel.PWM.SetActinic( ElseMode(30,10,false) );
ReefAngel.Relay.Off(Port8);
ReefAngel.Relay.On(Port8);
if( ReefAngel.DisplayedMenu==FEEDING_MODE )
ReefAngel.PWM.SetActinic(0);
ReefAngel.PWM.SetDaylight(0);
