no internal memory
Re: no internal memory
Use the wizard to create the code. It's easier to set the controller and settings with it.
i do that but the message are:"an error was occurred please try again"
i can only "generate" but not "upload and generate"
hawaii
hawaii
So generate and then save the file. Then try again to upload. This way you can see what the upload error is.
Inievo
i try to do what you propose
same thing, i Upload the code
here is what i found
On the RA main menu or setup :LED PMW
Setup LED what means "AP" and "DP"
i have the value 20% on each
hawaii
ReefAngel.LightsOnPorts = Port7Bit | Port8Bit;
ReefAngel.Relay.On( Port5 );
ReefAngel.Relay.On( Port7 );
ReefAngel.StandardHeater( Port1,245,260 );
ReefAngel.DosingPumpRepeat( Port2,0,60,60 );
ReefAngel.CO2Control( Port3,701,699 );
ReefAngel.StandardATO( Port4,300 );
ReefAngel.StandardLights( Port6,11,0,23,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(11,0,22,0,15,100,15) );
ReefAngel.PWM.SetActinic( PWMParabola(10,0,23,0,15,100,15) );
hawaii
I forget i don't have the possibilities to change the time and date
hawaii
hawaii
Put this in the setup custom code section
ReefAngel.AddDateTimeMenu();
AP = Actinic Port
DP = Daylight Port
AP = Actinic Port
DP = Daylight Port
We need to know what the error that you are getting and not your code.
I have a feeling that you have a standard RA that has very limited memory space and you are going above the memory capacity.
What RA do you have?
i do what you tell me but, not working
i put the code here tell me if it's correct:
on the wizard screen on the little windows down i have this in frenchi cannot copy:
binary size of the sketch: 34 162 octets (max 32256)
processing.app.debug.RunnerException: Sketch to big
http://www.ardino.cc/en/guide/Troubleshooting#size for help
at processing.app.Sketch.size (Sketch.java:1844)
at processing.app.Sketch.build (Sketch.java.1775)
at processing.app.Sketch.exportApplet (Sketch.jav.1797)
at processing.app.Sketch.exportApplet (Sketch.java.1783)
at processing.app.Editor$DefaultExportHandler.run Editor.java:2357)
at java.lang.Thread.run(Thread.java:619)
=> The RA is a standard and old one about 3 years now
hawaii
then upload nothing////// Place your custom code below here
hawaii
There is your problem.
You don't have enough space upload this code.
Your RA has a very limited memory size and you are trying to do too much with it.
I recommend you upgrading to the RA+ and you won't have any problems with memory size.
Your other options to download an older version (1.0.9) of the libraries and try with that.
Inevo
You give me right solution
everything is working good now
so, i will finally enjoy to play with
merci beaucoup
hawaii
merci beaucoup
hawaii
