Hi, I'm new in the forum and if possible need your Help
First my RA doesn't keep the time and date, that cause a problem for my light timing....
Second, if I want to change power % of my leds with the wizard, it tells me that I have no sufficient memory.
Whats the problem ??
Ho i havé the first generation...
RA problem
Re: RA problem
The battery is probably drained and needs to be replaced.
Unfortunately the standard RA doesn't have an easy to replace battery. It requires you to desolder and solder a new one.
You can send back for repair though. PM me for RMA if you want to go that route.
For more memory, I would recommend you upgrading to RA+. It would also fix the battery problem.
Re: RA problem
Ok cool for the battery replacement and I will pm you...
The only thing that i find weird, it's the memory problem.... it work like that and never had a problem, I just want to increase the % of the light and it doesn't work any more.
Re: RA problem
Newer libraries. You could download older ones to make it fit
