pH probe issue?
89delta
pH probe issue?
Post by 89delta »
I recently bought a new pH probe. After calibrating it my readings were between 8.2-8.42. After getting home from work my pH was at 9.46 and has climbed to 10.46-10.51.... I recalibrated it again, still same reading....Is my probe shot?
89delta
Re: pH probe issue?
Post by 89delta »
I figured it out fellas...I shoulda checked everything....and I mean everything first. The pump for my skimmer is leaking 1.8v AC into the tank causing the probe to go nuts. After turning it off the readings are fine again. Time to invest in a ground probe for the tank.
Re: pH probe issue?
Better to invest in a new skimmer pump
Re: pH probe issue?
Agreed. :D
89delta
Re: pH probe issue?
Post by 89delta »
I have too now. The pump quit working. But its $45 for a new pump or $114 for a new "improved" model.....ugh....lol
Re: pH probe issue?
Eshopps? My original came with an Atman pump that leaked voltage and I upgraded to the Sicce one. Big difference in quality and my ph stays stable now.
morn623
Re: pH probe issue?
Post by morn623 »
I currently have a ground probe in my tank and it did not help the issue when I had a faulty float switch.
89delta
Re: pH probe issue?
Post by 89delta »
Am using the aqualife 115 until I get the new tunze 9001
