ATO low/high as output.
billw
Post by billw »
I have a 1300 watt heater (3 Finnex elements and a Ranco controller) in my system that I plan on interfacing to the Reef Angel with a relay (http://www.powerswitchtail.com/Pages/default.aspx) driven with either of the ATO outputs. What is the drive capability of these outputs?
Any other alternative solution to my heater interface is welcome :mrgreen: .
Re: ATO low/high as output.
Yeap, you can connect straight up into the ATO port :)
billw
Post by billw »
rimai wrote:Yeap, you can connect straight up into the ATO port :)
Thanks, Roberto!
