Extending Cables
- ewaldsreef
- Contact:
Extending Cables
How far can the temp probe be extended? I am plumbing a tank in the basement and would like to run one of the temp probes about 30 ft. Is this to far?
Also in this same application can a secondary relay box be extended this distance? Best to use a longer serial cable, usb cable or combination of the two? I would use the RANet but would also like to add a few modules to the second box.
Re: Extending Cables
I'm not sure about how far the cables can go, but you can't add modules to the second box.
The USB, and dimming ports are non functional. Only the power ports work on the 2nd relay so the RANet maybe your better option.
- ewaldsreef
- Contact:
Used 20 ft of wire and a 10ft RA temp probe. 30 feet was a good est. It appears to be working well. Now I have a live feed on my frag system.
Since the usb port on a second relay box would not serve a function I will most likely go RANet but might look into trying to see if I can get a good signal from usb at that distance.
To add more temp probes you can splice the wires and run them in parallel?
Thanks so much for the help.
I don't think splicing the cables in parallel wil work.
The readings will get mixed together and how will you tell which is temp 4 and which I'd temp 5.
I'd like to you how to add more too.
Roberto says you can add upto 6, but it a hardwate modification.
Yes, just splicing in parallel works. This is the hardware mod needed.
You also need this in setup
ReefAngel.AddExtraTempProbes;
- ewaldsreef
- Contact:
Cool. I will grab a few more probes on my next order. I was thinking It would be good to add one for my water change barrel as well as basement room temp.
does not display or show in my app. i was unaware that this functionality existed.Sacohen wrote:How does it show up on the Portal or Apps?
guess I'll have to look into it and see if I can get it added to my app. gonna get the update out first.Sacohen wrote:
Sent from my Moto X
No problem. The debug version has been pretty stable besides those issues we've pointed out.
that's great to hear. it's coming along slowly.Sacohen wrote:No problem. The debug version has been pretty stable besides those issues we've pointed out.
Sent from my Moto X
- ewaldsreef
- Contact:
Binder, I have been super happy with the app.
awesomeewaldsreef wrote:Binder, I have been super happy with the app.
