Possible bad float switch
MDB1029
Post by MDB1029 »
The float switch I was using as my ATO seems to have stopped working properly. I replaced it with the other and the ATO resumed normal function. I was wondering if there was a way to test if the switch was working properly or not since i have another use for the second switch?
pandimus
Re: Possible bad float switch
Post by pandimus »
Multimeter? Check continuity on both leads with switch in both positions
