Error uploading
Error uploading
it has been long time since last time I uploaded a code
now I cant upload after compiling i receive
Error uploading message in the bottom
Watchdog Timer
Version Menu
Simple Menu
حجم السكتش المترجم: 22,008 بايت ( 258,048 كحد أقصى
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -V -Uflash:w:C:\Users\waleed\AppData\Local\Temp\build6026811067102450045.tmp\sketch_jun18b.cpp.hex:i
Using Port : \\.\COM5
Using Programmer : stk500v2
Overriding Baud Rate : 115200
avrdude: Send: . [1b] . [01] . [00] . [01] . [0e] . [01] . [14]
avrdude: Recv: . [12]
avrdude: Recv: . [00]
avrdude: Recv: . [02]
avrdude: Recv: . [0c]
avrdude: Recv: . [04]
avrdude: Recv: . [1e]
avrdude: Recv: [20]
avrdude: Recv: ` [60]
avrdude: Recv:
avrdude done. Thank you.
please help me to resolve the issue
Watchdog Timer
Version Menu
Simple Menu
avrdude: Recv: [20]
avrdude: Recv:
Re: Error uploading
check what board is selected. the newer ones are reef angel with optiboot. you may want to try other board options to see if it makes a difference.
Re: Error uploading
Hi Binder
Tried it it sayes skitch is too large
My controller is Reef Angel Plus
Re: Error uploading
if you have the plus, then you will need to use that board selection. you will not get a sketch too big error with the plus.
also, make sure you have the cable plugged in properly when trying to upload. since the serial cable is smaller than the actual number of pins, people sometimes plug it in wrong.
Sent from my Nexus 7
Re: Error uploading
always choose Reef Angel Plus
this time it didn't work
I even tried new TTL cable same >>>
it blinks when I connect it
I dont know where to go next
Re: Error uploading
hmmmm, Roberto will probably have to chime in for additional input.
Sent from my Moto X
Sent from my Moto X
Re: Error uploading
Does this happen on every code you try to upload?
Try the Template in the examples folder.
Re: Error uploading
Hi Rimai
I am afraid to try the Template and then cant load again My tank relay on the Reef angel
I tried from new wizard it didn't work. also gave me same result
Re: Error uploading
Seems there is something wrong with the board then.
If you want to send it in for analysis, PM me.
Re: Error uploading
Hi all
I tried even the Template in the examples folder.
still :
Watchdog Timer
Version Menu
RF Expansion Module
Wifi Attachment
Relay Expansion Module
Water Level Expansion Module
2014 Main Screen
Salinity Expansion Module
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 62,834 bytes (of a 258,048 byte maximum)
C:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/bin/avrdude -CC:\Program Files (x86)\Reef Angel Controller\hardware/tools/avr/etc/avrdude.conf -v -v -v -v -patmega2560 -cstk500v2 -P\\.\COM5 -b115200 -D -V -Uflash:w:C:\Users\waleed\AppData\Local\Temp\build9125265723131173521.tmp\sketch_jul11b.cpp.hex:i
avrdude: Recv: [20]
avrdude: Recv:
still :
Watchdog Timer
Version Menu
RF Expansion Module
Wifi Attachment
2014 Main Screen
Simple Menu
avrdude: Recv: [20]
avrdude: Recv:
Re: Error uploading
Are you sure it's the right COM port?
Re: Error uploading
Hi cosmith71 yes there is only one option
Re: Error uploading
i have been having the same issue with the timing out error code. did you ever get it working? it doesnt matter what usb port i use, what software i use to upload or what code. i get the red flashing light on the controller when i plug it in and unplug it. it also does it when its starts to upload then it just gives up.
Re: Error uploading
dear nofearonabike07
until now I cant upload
DEAR RIMAI
it was fine before I uploaded several codes.
now it does not continue
DEAR RIMAI
