Help with salinity
Help with salinity
I just installed my Reef Angel and I can't seem to get a reading on my salinity. I have it connected to an expansion module along with the ph. PH is working fine. The salinity reads 5.9 in the water out of the water and when unplugged. Tried calibrating it but still no change. Any ideas?
Re: Help with salinity
Anyone?
It just stays at 5.9. Never changes.
It never changes even while calibrating.
Maybe I'm missing something but when I hit the calibrate salinity it just says Ok. I also seem to be having an issue with my ph probes as well. They read the same weather in the water or out. I have one on an expansion and one on the controller it self. I will have the calibrating solution today. How can I tell if the probes are working at all? No matter what type of water I put the salinity probe in it never changes the number on the controller.
I think so too.
Can you post a photo?
It should have more than just ok button.
Yes, I will post a photo tonight when I get home.
