I added a float valve to my skimmer drain container, so that the skimmer would shut down if the container fills up. However, after adding the following code I found that it completely cancelled out my skimmer delay settings. Is it possible to have the delay and the "override"?
ReefAngel.Relay.Override(Port8,0);
ReefAngel.Relay.On(Port8);
Lost skimmer delay setting.
Re: Lost skimmer delay setting.
Take out the else. You use an override because you want to manually enable the skimmer after this type of event.
That worked perfectly. thank you, thank you, thank you!
Ted
Ted
