Feeding mode
ucez
Feeding mode
Post by ucez »
Trying to turn off return and skimmer, during feeding mode, but only the skimmer is turning off. Code is below.
I was wondering if this could have something to do with turning the return pump off/on using the portal or app. Do I need reset something via the app/portal? For some reason the app has green lights next to some of the on/off buttons. I thought it was for anything that was "always on", but that's not the case.
// Define Relay Ports by Name
#define Return_Pump     1
#define Siphon_Valve    2
#define Skimmer         3
#define Heater          4
#define Fuge_Light      5
//Define Relay 1 Ports by Name
#define FragHeater      Box1_Port1
#define FragPowerhead   Box1_Port2
#define FragLED1        Box1_Port3
#define WaterChange     Box1_Port4
#define FragLED2        Box1_Port5
#define BrutePump       Box1_Port7
  ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
  ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
  ReefAngel.Relay.On( Return_Pump );
  ReefAngel.Relay.On( FragPowerhead);
  ReefAngel.Relay.On( WaterChange);
  ReefAngel.Relay.On( BrutePump);
  ReefAngel.Relay.Set( Siphon_Valve, !ReefAngel.Relay.Status( Return_Pump ) );
  ReefAngel.Relay.DelayedOn( Skimmer,10 );
  ReefAngel.StandardHeater( Heater,800,810 );
  ReefAngel.StandardLights( Fuge_Light,21,0,7,0 );
  ReefAngel.StandardLights( FragLED1,9,0,19,0);
  ReefAngel.StandardLights( FragLED2,9,0,19,0);
  //if HighATO.IsActive=false, then turn off Port 1
  if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Return_Pump);
  else ReefAngel.Relay.On(Return_Pump);
  //frag tank heater
  if (ReefAngel.Params.Temp[T2_PROBE]>810) ReefAngel.Relay.Off( FragHeater );
  if (ReefAngel.Params.Temp[T2_PROBE]<800) ReefAngel.Relay.On( FragHeater );
  ReefAngel.Portal( "ucez" );
  ReefAngel.DDNS( "Reef" ); // Your DDNS is ucez-Reef.myreefangel.com
ucez
Re: Feeding mode
Post by ucez »
Never mind, I read the app manual and turned off the overrides...
