I was wondering if this could have something to do with turning the return pump off/on using the portal or app. Do I need reset something via the app/portal? For some reason the app has green lights next to some of the on/off buttons. I thought it was for anything that was "always on", but that's not the case.
// Define Relay Ports by Name
#define Return_Pump 1
#define Siphon_Valve 2
#define Skimmer 3
#define Heater 4
#define Fuge_Light 5
//Define Relay 1 Ports by Name
#define FragHeater Box1_Port1
#define FragPowerhead Box1_Port2
#define FragLED1 Box1_Port3
#define WaterChange Box1_Port4
#define FragLED2 Box1_Port5
#define BrutePump Box1_Port7
ReefAngel.FeedingModePorts = Port1Bit | Port3Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port3Bit;
ReefAngel.Relay.On( Return_Pump );
ReefAngel.Relay.On( FragPowerhead);
ReefAngel.Relay.On( WaterChange);
ReefAngel.Relay.On( BrutePump);
ReefAngel.Relay.Set( Siphon_Valve, !ReefAngel.Relay.Status( Return_Pump ) );
ReefAngel.Relay.DelayedOn( Skimmer,10 );
ReefAngel.StandardHeater( Heater,800,810 );
ReefAngel.StandardLights( Fuge_Light,21,0,7,0 );
ReefAngel.StandardLights( FragLED1,9,0,19,0);
ReefAngel.StandardLights( FragLED2,9,0,19,0);
//if HighATO.IsActive=false, then turn off Port 1
if (!ReefAngel.HighATO.IsActive()) ReefAngel.Relay.Off(Return_Pump);
else ReefAngel.Relay.On(Return_Pump);
//frag tank heater
if (ReefAngel.Params.Temp[T2_PROBE]>810) ReefAngel.Relay.Off( FragHeater );
if (ReefAngel.Params.Temp[T2_PROBE]<800) ReefAngel.Relay.On( FragHeater );
ReefAngel.Portal( "ucez" );
ReefAngel.DDNS( "Reef" ); // Your DDNS is ucez-Reef.myreefangel.com
