I have a 300 watt heater. Is it ok to plug into the RA relay box, or does it exceed the specs? I'm wondering if it would be better to use two smaller heaters.
Ted
Does 300 Watt heater exceed RA specs?
Re: Does 300 Watt heater exceed RA specs?
Really depends on the amps.paperdesk wrote:I have a 300 watt heater. Is it ok to plug into the RA relay box, or does it exceed the specs? I'm wondering if it would be better to use two smaller heaters.
Ted
I'm running a 500 watt Finnex on mine, with no problems.
5A per outlet, with a 10A max for the box.
300W/120v = 2.5A (assuming you're in the US) so you should be fine.
Thanks guys! I wasn't able to find those specs.
