I get the following when trying to upload the code above:
Watchdog Timer
Version Menu
Simple Menu
Binary sketch size: 466 bytes (of a 32,256 byte maximum)
avrdude: stk500_recv(): programmer is not responding
lnevo wrote:You've got the wrong board configured if this is an RA+. It's saying you only have 32k available which means it's looking for a standard board.
I have been using Reef Angel Controller w/optiboot. Should I use Reef Angel Plus Controller? Sorry for the dumb question.
Sent from my Nexus 6 using Tapatalk
Many thanks. I did not see you had posted when I asked using Tapatalk.
Just tried with the board set to Reef Angel Controller and serial port set to /dev/tty.usbserial-A901MIKW. I got the following error:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Relay Expansion Module
Dimming Expansion Module
2014 Main Screen
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 60,704 bytes (of a 258,048 byte maximum)
So I have tried running the controller with just the dimming expansion no bus lock. I tried running the controller with the expansion hub and dimming module- bus lock. Expansion hub and expansion hub- bus lock. This leads me to think that maybe my expansion hub is bad. I noticed the led on the expansion hub starts off bright and then goes dim to off as time passes. Maybe Rimai will let me exchange it for a working one. I also have yet been able to update my code. I am not sure what else to do/check. I have changed all of the USB cables.
