Reef Angel AWOL
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Just tried with the board set to Reef Angel Controller and serial port set to /dev/tty.usbserial-A901MIKW. I got the following error:
Watchdog Timer
Version Menu
Dimming Signal
Wifi Attachment
Relay Expansion Module
Dimming Expansion Module
2014 Main Screen
Number of Relay Expansion Modules: 1
Simple Menu
Binary sketch size: 60,704 bytes (of a 258,048 byte maximum)
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
So I have tried running the controller with just the dimming expansion no bus lock. I tried running the controller with the expansion hub and dimming module- bus lock. Expansion hub and expansion hub- bus lock. This leads me to think that maybe my expansion hub is bad. I noticed the led on the expansion hub starts off bright and then goes dim to off as time passes. Maybe Rimai will let me exchange it for a working one. I also have yet been able to update my code. I am not sure what else to do/check. I have changed all of the USB cables.
Sent from my Nexus 6 using Tapatalk
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Expansion hub and expansion module. The one that allows for an set of relays to plug equipment into.lnevo wrote:Expansion hub and expansion hub?
- Rodasphoto
- Contact:
Re: Reef Angel AWOL
Just tried upload the code above and got the following errorrimai wrote:Does i0t hangs on 90% on any code?
Try this code:Code: Select all
void setup() { } void loop() { }
avrdude: stk500v2_command(): unknown status 0x01
avrdude: stk500v2_disable(): failed to leave programming mode
