Ph probe interference?
najluni15
Post by najluni15 »
Hi all
I'm having trouble with my ph probe. In my sump or display it reads a solid 3.02. But when I calibrated it or put it in a cup of tank water it is accurate. Also when I unplug my skimmer or my return pump from the reef angel the probe is accurate. I'm thinking it's interference or a ground loop. Can anybody help me figure this out?
Nick
najluni15
Re: Ph probe interference?
Post by najluni15 »
Also, my ph probe is brand new and when in buffer it reads 7.0 and 10.0 respectively. Right now I unplugged everything from the relay one by one and put the probe in a cup of tank water. unplugging everything did not help. The ph probe was stuck at 6.02. I tried my code with and without my line with the ph calibration values. Here is my current code
ReefAngel.FeedingModePorts = Port2Bit | Port3Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port6Bit;
ReefAngel.PHMin=405;
ReefAngel.PHMax=805;
ReefAngel.Relay.On( Port3 );
ReefAngel.Relay.On( Port4 );
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,781,791 );
ReefAngel.Relay.DelayedOn( Port2,5 );
ReefAngel.SingleATO( true,Port6,60,0 );
ReefAngel.StandardHeater( Port7,781,791 );
Something is causing stray voltage. Can you get a meter to check.
najluni15
Post by najluni15 »
I'll test for stray voltage and see. It must be one of those two pumps. Or both.
najluni15
Post by najluni15 »
So I tested my gfci for ground and it is grounded. I then tested for stray voltage and found only .1 volts. I then added two grounding probes to the tank hoping it would help aND it didn't. Any other ideas? Maybe it's just the magnetic field of those pumps? But that wouldn't explain why the reading if the probe is in the display wouldn't work.
I had a similar issue with the same symptoms. Turned out to be a bad probe (cracked insulation, I suspect).
najluni15
Post by najluni15 »
Thanks for the reply. That's what I initially thought so I ordered a new one and the new one is having the same issue. The new probe calibrates fine and reads fine if I put it in a cup of tank water.but if it is in the tank it doesn't read correctly.
Is it submerged? Try putting it in the tank with the top out of the water.
najluni15
Post by najluni15 »
The top is out of the water in a probe holder
jsclownfish
Post by jsclownfish »
I have this same issue when one of my flow meters starts to go bad. The pH meter is a quick indicator that one is going bad as even a small voltage leak causes the pH to drop quickly. If you simply start unplugging the potential offending instrument, you should be able to see it jump back up.
-Jon
Also float switches could cause it too.
najluni15
Post by najluni15 »
Ok. I did a big water change etc on my tank today. I reset reef angel and immediately the ph went up to 6.7 (still wrong but closer). The protein skimmer was the only thing off at this time. As soon as the protein skimmer turned on the ph dropped down again. Now when I turn off the skimmer shouldn't the ph raise again? It seems to get stuck at the same number even when I restart the reef angel.
jsclownfish
It can take a little while for the pH to climb back up. For instance, when I calibrate I leave the probe in the calibration buffer for 5-10minutes to allow it to settle in.
Jon
tmoore103
Post by tmoore103 »
Was this issue ever resolved? Sounds really similar to an issue I'm having.
