Got a Question...
I have 2 controllers in my house.
Ones is being used on my main system (350 gallon system) and the other one is on the garage on my frag system.
I noticed one day after uploading code to the frag tank controller, I had a cool new menu.
It let me adjust the PWM settings, and the heater settings, and choose lights on from the controller.I remember being able to do this originally a few years ago.
But the other controller has the 2014 menu all the way thru. No lights on/lights off menu.
My question is, what about the two different codes is making it do that?
And how do I get the Lights on menu on my main system?
I'll post both codes in separate replies in just a moment.
Two Controllers with Two Different Menus
Re: Two Controllers with Two Different Menus
Main system code
Picture of Menu
ReefAngel.FeedingModePorts = Port1Bit | Port2Bit | Port6Bit | Port7Bit;
ReefAngel.FeedingModePortsE[0] = Port5Bit;
ReefAngel.WaterChangePorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port6Bit | Port7Bit;
ReefAngel.WaterChangePortsE[0] = Port5Bit;
ReefAngel.LightsOnPorts = Port4Bit | Port5Bit | Port8Bit;
ReefAngel.LightsOnPortsE[0] = Port1Bit | Port2Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit;
// Setup ATO Port for AI communication
ReefAngel.AI.SetPort( lowATOPin );
ReefAngel.Relay.On( Port2 );
ReefAngel.StandardHeater( Port3,780,785 );
ReefAngel.StandardFan( Port4,785,790 );
ReefAngel.StandardLights( Port5,22,0,6,0 );
ReefAngel.Relay.DelayedOn( Port6,1 );
ReefAngel.WaterLevelATO( Port7,60,90,100 );
ReefAngel.StandardLights( Box1_Port1,8,0,20,0 );
ReefAngel.StandardLights( Box1_Port2,12,0,18,0 );
ReefAngel.DosingPumpRepeat( Box1_Port3,0,30,240 );
ReefAngel.DosingPumpRepeat( Box1_Port4,30,30,240 );
ReefAngel.StandardLights( Box1_Port8,9,0,19,0 );
ReefAngel.PWM.SetDaylight( PWMParabola(6,0,22,0,0,100,0) );
ReefAngel.PWM.SetChannel( 0, PWMParabola(7,0,22,0,0,75,0) );
ReefAngel.PWM.SetChannel( 1, PWMParabola(7,0,22,0,0,75,0) );
ReefAngel.PWM.SetChannel( 2, PWMSlope(10,0,18,0,0,65,120,0) );
ReefAngel.AI.SetChannel( White, PWMParabola(11,0,18,0,0,75,0) );
ReefAngel.AI.SetChannel( Blue, PWMParabola(8,0,21,0,1,100,1) );
ReefAngel.AI.SetChannel( RoyalBlue, PWMParabola(8,0,22,0,1,100,1) );
ReefAngel.DCPump.SetMode( Else,50,10 );
ReefAngel.DCPump.ExpansionChannel[3] = Sync;
ReefAngel.DCPump.ExpansionChannel[4] = AntiSync;
ReefAngel.DCPump.ExpansionChannel[5] = AntiSync;
ReefAngel.Relay.Override(Port6,0);
ReefAngel.Portal( "lionfan" );
Picture of Menu
- IMG_20151129_165443586.jpg (1023.51 KiB) Viewed 6671 times
Frag system code
Picture of Menu
ReefAngel.OverheatShutoffPorts = Port3Bit | Port4Bit | Port5Bit | Port6Bit;
if (ReefAngel.Params.Temp[T2_PROBE]>800) ReefAngel.Relay.Off(Port7);
if (ReefAngel.Params.Temp[T2_PROBE]<790) ReefAngel.Relay.On(Port7);
if (ReefAngel.Params.Temp[T3_PROBE]>800) ReefAngel.Relay.Off(Port8);
if (ReefAngel.Params.Temp[T3_PROBE]<790) ReefAngel.Relay.On(Port8);
ReefAngel.Relay.On( Port7 );
ReefAngel.Relay.DelayedOn( Port2,1 );
ReefAngel.StandardLights( Port4,8,0,18,0 );
ReefAngel.PWM.SetDaylight( PWMSlope(11,0,17,0,0,50,80,0) );
ReefAngel.PWM.SetActinic( PWMParabola(8,0,21,0,1,50,1) );
if(ReefAngel.LowATO.IsActive())
ReefAngel.Relay.Override(Port1,0);
Picture of Menu
The only difference I see is this line:
It's in the frag tank code, but not in the main system code.
I get that screen when I push in on the joystick.
The wizard did both codes for me, minus some small custom code.cosmith71 wrote:The only difference I see is this line:
It's in the frag tank code, but not in the main system code.Code: Select all
I wonder why it loaded on one, and not the other?
Both RA+? Not sure why.
yea, both are RA+'s, same wizard, same computer, just different options chosen in the wizard. Must be just a small bug with the wizard.cosmith71 wrote:Both RA+? Not sure why.
Which Menu is the newest, and with the current libraries?
Now that you mention it, I seem to recall having that functionality when I first set up my RA 4-5 years ago, somewhere along the way it seems to have disappeared. If I had to guess, I'd say I haven't had it since I switched from T-5s to LEDs.
My T-5s were just plugged in to my RA but the LEDs are on a PWM module. The wizard may include or omit it based on how your lighting is set up. Do you have the same lighting on both tanks?
