Relay Going Bad?
Re: Relay Going Bad?
Is it doing on both or just one box?
Your original post days one and then you said both.
If just one, which box is it?
hnnhflns
Post by hnnhflns »
It's both boxes now. It started out as just the expansion, but it is now both the expansion and the original box.
Try moved the USB cables and any expansion module away from mains power cords, especially if you have MH ballasts.
Unplug and plug all usb connectors back in to make sure all cables are seated properly.
Do you have an expansion hub or the relay expansion is connected directly to the main relay box?
hnnhflns
Post by hnnhflns »
For the most part, at least lately, it has been working properly. We don't have MH ballasts.
It appears that the Water Level Sensor has been causing one of the relays to trip. Unplugged all the expansions and it stopped as well.
