Temp Overheat
Re: Temp Overheat
I did replace the temp probe early this morning, so we will see if that helps. I checked the connections and all seems fine. I still don't understand what is going on with my PH probe. Right now it is reading 5.3. Later it will drop down to 1 them back up again. The only time it read right was when I first calibrated it. Now it never gets higher then in the fives.
Re: Temp Overheat
Probe is either getting stray voltage or its shot. How old is the probe?
Re: Temp Overheat
I placed the probe in a glass of water and it didn't change. It's maybe a month old.
Re: Temp Overheat
Not off hand. I can recalibrate to see.
Re: Temp Overheat
Here are the numbers i got when I recalibrated the probe. pH 7 was 344 and pH 10 was 575.
Re: Temp Overheat
Yes, it did. The first time I calibrated it, it acted the same way. It took about a month or so then it started to drop until it reached one. Could it be that it's just a cheap pH probe?
Re: Temp Overheat
At the moment, yes. But it's already going down. It staarted at 7.47 and now it's 6.99 and dropping.
Re: Temp Overheat
I guess it's what I get for buying a real inexpensive probe.
