WIFI Port Forwarding problems with Airport Extreme
Re: WIFI Port Forwarding problems with Airport Extreme
I cannot log into the server through that address either. Perhaps there is some issue with the router?
I can get into the router through the airport utility application.
Open the Airport utlity, click manual setup, on the summary page click dhcp clients. It will show you the mac address of all the connected clients.JJones wrote:Pardon my ignorance, but how do I do that?
Did you configure a static ip on the RA or inside of the Airport Utility? It should be done inside the Airport utility, if you configure it on the RA the Airport still thinks it is open and can assign that address to another device knocking them both offline. To reserve on Airport go to Internet >> DHCP >> Reservations and enter in IP and mac address of adapter.
Let me know if you need screen shots and I can show you how mine is configured.
Thanks for the help everyone.
I can see the mac addresses of the devices connected. There are 5, is there a way to tell which belongs to the RA?
As far as configuring a static IP, I think I did that incorrectly. I configured it on my PC laptop for the laptop. I having been working mainly from other posts, so if there is a detailed step by step, that would be helpful.
simply way is try to browse to each one of those address's, if you get to the reefangel then you know you got the right one. Then you can reserve that IP on your airport so it will always stay with that address.JJones wrote:Thanks for the help everyone.
http://10.0.1.11:2000/wifi
Just substitute the other ip's.
As for the static if you didn't knowingly set one its probably set for DHCP and will grab whatever address the DHCP server gives it. Usually it is the same address everytime but it can change so it is best to "reserve" it.
Ok. Now that is complete. So now should I modify the port forwarding to the ip address that is assigned to the RA?
It moved to 10.0.1.2. That is the address I then reserved it too.
I used port mapping to open port 2000 for 10.0.1.2.
I still does not seem as though the port is forwarding. When I try to connect to 10.0.1.2 from the iphone app, it only works when I have it connected to my home wireless. Is there another IP address I should be connecting to?
Yes, when you are outsite of your house, you have to use your external ip address.
Find out what it is by using a computer inside your network and go to http://whatismyip.com
This will tell you what external ip address you are using.
Then, you setup the iphone app to use that ip address.
Ok, that step is done and it is still not working.
Any other suggestions?
John, can you show me screenshots of your configuration to make sure I am not missing anything. Do I need to mess with IPv6?
Do not bother with IPv6. It won't make a difference.JJones wrote:Ok, that step is done and it is still not working.
What can happen is your public IP address can change. It is usually dynamically assigned from your provider. You may want to test that it has stayed the same. And you should visit that site from your home computer and not on your 3G/4G connection from your phone. (just in case you were doing that).
I will grab some screenshots tonight.JJones wrote:Ok, that step is done and it is still not working.
sorry a bit late.
My RA is configured for 10.0.1.11
- Screen Shot 2012-01-22 at 5.22.52 PM.png (132.4 KiB) Viewed 6627 times
Thanks for posting that John.
My port forwarding is set up the same as John's. I have checked my external IP address the last few days and it has stayed the same.
However, I cannot connect through my iphone of through http://99.67.237.227:2000/wifi. I can connect through 10.0.1.2:2000 wifi.
Is it possible there is some issue with my service provider causing this? Use AT&T Uverse.
When you browse http://whatismyip.com, are you using your computer or your iPhone?
Computer every time
Anyone else have any ideas?
Problem fixed.
Roberto remotely logged in and figured out the problem. While I had the airport set up to forward properly, I never forwarded the Uverse router that it was connected to. Once we forwarded that, everything worked like a champ.
Thanks again Roberto.
