Reef Angel Plus and tons of extras FS
Anybody looking for a full set up of a reef angel? I have one for sale with tons of extras. PM me if interested.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Re: Reef Angel Plus and tons of extras FS
Troy Long was...gonna let him know.
Thanks lnevo!
Did you talk to troy long? I have a lot of requests to part it out but was looking to sell the whole thing. If troy wants it but only wants some I will part it out.
Yea but he couldnt find thread. I linked him but he hasnt replied yet. He may only be interested in the dimming module if you have one, but he might want more.
That's the one thing I don't have. Would need a buyer for the head unit before I part it out.
I finally checked out the link Lee thanks lol. I don't have nothing on me right now. But what all do you have? If no sells yet
troylong45, sorry I didn't see this message before. below is a list of what I have for sale. I will be parting it out or selling as a whole. I am going on vacation in the last week of July and want to hold onto the controller until then but can sell some pieces now. Let me know if you are interested.
Reef Angel Controller $200
ph expansion w/probe $75 Avl. Now
ph expansion wo/probe $60 Avl. Now
salinity expansion $100
wifi $75
expansion hub $25 Avl. Now
expansion hub $25
leak detector $75 Avl. Now
water level $30
8 outlet $70
8 outlet $70
temp $10
temp $10
Humidity $25 Avl. Now
wifi $75
expansion hub $25
water level $30
8 outlet $70
8 outlet $70
temp $10
temp $10
I am interested in this but have a few questions. I have been looking to get a Reef Angel system and this seems very serendipitous.
Doesn't the Controller itself have a salinity and PH port? Are the expansions you have for PH and salinity for PH and salinity probes in addition to the ones that come on the controller?
I am just now starting into the hobby so don't really need a ton of extra sensors.
I think I would mainly be interested in:
Controller + PH and Salinity probe to use with the built in ports
8 outlet to controlle return pump, heaters, skimmer, ato pump, lights etc...
Water Level expansion for use as ATO
Wifi expansion
Expansion hub
Temp prove
Leak detector
That seems like it would make for a really good starter system. I am new to this so let me know if I am missing anything else I would need.
What do you use the humidity sensor for? Humidity in the room or inside your stand. I'm trying to think if there is any meaningful way I could use this.
Wifi expansion
Expansion hub
Temp prove
Leak detector
To answer your questions about the probes...the controller only comes with the connection for one ph probe and no salinity probe. If you want to do salinity you will need the salinity expansion module. That module connects to the outlets by usb. If you wanted to do more photos probes, another set of outlets, the leak detector, etc. you will need the expansion hub. The humidity can be used for checking humidity in the room, sump area, canopy. To be honest I never used it and connected it once and didn't see any data so I disconnected it and never messed with it again. The water level is amazing and works great for a top off. Make me an offer for what you are interested in and we can go from there.
It seems I am too new here to send a PM. Maybe if you send me a PM I can reply?
If I am reading the website correctly it says for $269 I would get the following if I bought new:
Reef Angel Plus Controller
Relay Box
HDDB15 Communication Cable
PH Probe
Temp probe
2x float switch
2x float switch connectors
USB TTL converter
USB Power cable
Are you including the cables and such or only exactly what you have listed?
Relay Box
PH Probe
Temp probe
2x float switch
USB TTL converter
USB Power cable
fishflipper:
I pm'd you...
I pm'd you...
I don't see a pm
Just sent it again, do you have it now?
Do you think the humidity expansion is working? you say you didn't get any data...
I'm interested in the expansion modules if still available ?
Yes, still available
It is the USB expansion correct? New style or old? Square or long rectangle?
Do you have relay expansion also?
Both mine are shot?
Both sold if you have them. If not I'll take sub expansion
I think it's kinda rectangular. I have 2 hubs. There is someone else who is interested in one of them but everything else is still available.
Pm me how much for a usb expansion and the relay. Expansion. PayPal you tomorrow
Wanted to say thanks again. I'm back up and running. Also found bad float switch during fix. So it was a double positive.
Do you still have a relay expansion? Also can you use the pwm ports on the relay box for another dimming source?
Nope to this part.tech9 wrote:Also can you use the pwm ports on the relay box for another dimming source?
Here is what is available.
Reef Angel Controller $200 w/8 outlets and ph probe
wifi $75
leak detector $75
water level $30
temp $10
temp $10
wifi $75
leak detector $75
water level $30
temp $10
temp $10
pm'd
Offer $ 100 for the wifi, waterlevel, and 1 temp probe
Hi I am living in Canada. Do you still have some part available?
Yes, everything above is available except the wifi, water level and one of the temp probes
I am interested by the leak detector (I guess it includes expansion and rope). I was also interested by the water level(too late).Do you have the hub?
