Reef Angel Plus and tons of extras FS
re76
Re: Reef Angel Plus and tons of extras FS
Post by re76 »
It seems I am too new here to send a PM. Maybe if you send me a PM I can reply?
If I am reading the website correctly it says for $269 I would get the following if I bought new:
Reef Angel Plus Controller
Relay Box
HDDB15 Communication Cable
PH Probe
Temp probe
2x float switch
2x float switch connectors
USB TTL converter
USB Power cable
Are you including the cables and such or only exactly what you have listed?
You should be able to PM now :)
psyrob
Post by psyrob »
fishflipper:
I pm'd you...
fishflipper
Post by fishflipper »
I don't see a pm
Sent from my SAMSUNG-SM-G935A using Tapatalk
psyrob
Post by psyrob »
Just sent it again, do you have it now?
Do you think the humidity expansion is working? you say you didn't get any data...
bmhair03
Post by bmhair03 »
I'm interested in the expansion modules if still available ?
fishflipper
Yes, still available
bmhair03
Post by bmhair03 »
It is the USB expansion correct? New style or old? Square or long rectangle?
Do you have relay expansion also?
bmhair03
Post by bmhair03 »
Both mine are shot?
bmhair03
Post by bmhair03 »
Both sold if you have them. If not I'll take sub expansion
fishflipper
I think it's kinda rectangular. I have 2 hubs. There is someone else who is interested in one of them but everything else is still available.
bmhair03
Post by bmhair03 »
Pm me how much for a usb expansion and the relay. Expansion. PayPal you tomorrow
bmhair03
Post by bmhair03 »
Wanted to say thanks again. I'm back up and running. Also found bad float switch during fix. So it was a double positive.
tech9
Post by tech9 »
Do you still have a relay expansion? Also can you use the pwm ports on the relay box for another dimming source?
tech9 wrote:Also can you use the pwm ports on the relay box for another dimming source?
Nope to this part.
fishflipper
Here is what is available.
Reef Angel Controller $200 w/8 outlets and ph probe
ph expansion w/probe $75
ph expansion wo/probe $60
salinity expansion $100
wifi $75
leak detector $75
water level $30
temp $10
temp $10
Smotz
Post by Smotz »
pm'd
Offer $ 100 for the wifi, waterlevel, and 1 temp probe
pvado
Post by pvado »
Hi I am living in Canada. Do you still have some part available?
fishflipper
Yes, everything above is available except the wifi, water level and one of the temp probes
pvado
Post by pvado »
I am interested by the leak detector (I guess it includes expansion and rope). I was also interested by the water level(too late).Do you have the hub?
pvado
Post by pvado »
I may also interested by a temperature probe depending on his size. How long is it?
fishflipper
I still have the leak detector with the rope. I'm not sure if I have another hub. Your in Canada? Not sure what the shipping charges would be.
pvado
Post by pvado »
let me know for shipping charges. I am in montreal, Quebec, Canada
pvado
Post by pvado »
Hi,
did you get the chance to find the shipping charges?
fishflipper
I briefly looked it up last night. I think it will be around $25 US. I need to do a little more research to see if there is anything cheaper.
fishflipper
Would you only be interested in the leak detector?
fishflipper
Looks like the cheapest I can find is $25
pvado
Post by pvado »
hi
I was off for few days... 25$ that 's expensive as the item has no weight. Can you let me know what will be the total price?
the leak detector is an 8' rope plus a module and usb cable. USPS is pretty cheap though. It could fit in a flat rate box
fishflipper
USPS is pretty cheap to ship in the US but to ship to Canada the cheapest I found for a small flat rate envelope is $25. For the ph probe I have an extension cable for the probe which make it pretty long, I think around 15'. So if you wanted the leak detector module and ph module with probe and extension cable I could probable do $160 shipped. If your interested send me your address so I can get a definite price on shipping.
