Reef Angel Plus and tons of extras FS
Re: Reef Angel Plus and tons of extras FS
I think it's kinda rectangular. I have 2 hubs. There is someone else who is interested in one of them but everything else is still available.
Sent from my SAMSUNG-SM-G935A using Tapatalk
Pm me how much for a usb expansion and the relay. Expansion. PayPal you tomorrow
Wanted to say thanks again. I'm back up and running. Also found bad float switch during fix. So it was a double positive.
Do you still have a relay expansion? Also can you use the pwm ports on the relay box for another dimming source?
Nope to this part.tech9 wrote:Also can you use the pwm ports on the relay box for another dimming source?
Here is what is available.
Reef Angel Controller $200 w/8 outlets and ph probe
ph expansion w/probe $75
ph expansion wo/probe $60
salinity expansion $100
wifi $75
leak detector $75
water level $30
temp $10
temp $10
wifi $75
leak detector $75
water level $30
temp $10
temp $10
pm'd
Offer $ 100 for the wifi, waterlevel, and 1 temp probe
Hi I am living in Canada. Do you still have some part available?
Yes, everything above is available except the wifi, water level and one of the temp probes
I am interested by the leak detector (I guess it includes expansion and rope). I was also interested by the water level(too late).Do you have the hub?
I may also interested by a temperature probe depending on his size. How long is it?
I still have the leak detector with the rope. I'm not sure if I have another hub. Your in Canada? Not sure what the shipping charges would be.
let me know for shipping charges. I am in montreal, Quebec, Canada
Hi,
did you get the chance to find the shipping charges?
I briefly looked it up last night. I think it will be around $25 US. I need to do a little more research to see if there is anything cheaper.
Would you only be interested in the leak detector?
Looks like the cheapest I can find is $25
hi
I was off for few days... 25$ that 's expensive as the item has no weight. Can you let me know what will be the total price?
the leak detector is an 8' rope plus a module and usb cable. USPS is pretty cheap though. It could fit in a flat rate box
USPS is pretty cheap to ship in the US but to ship to Canada the cheapest I found for a small flat rate envelope is $25. For the ph probe I have an extension cable for the probe which make it pretty long, I think around 15'. So if you wanted the leak detector module and ph module with probe and extension cable I could probable do $160 shipped. If your interested send me your address so I can get a definite price on shipping.
I did not want the probe extension but only the wire extension because mine is too small. If you have a probe I may be interested.
So What I would like is : leak detector(including rope) + hub(if you have).
you originally quote at 75$ including US shipment fees. So now as it is shipped to Canada what is your price?
typo from my previous message. If you have a hub I will be interested as I cannot use the leak detecctor as such as I have already a salinity box connected to the relay
I do not have another hub, sorry. Price shipped to Canada should be $93USD. Send me your address so I can be definite on the shipping.
hi
shipping fees is far too expensive(not your fault) but 93$ is high for an used item. I was targeting 80$
I agree. Sorry we could make it work. Wish I could find cheaper shipping.
Do you still have anything for sell me relay boxjust quit
