Help with Buzzer code
Smotz
Post by Smotz »
'Lo all. I put this buzzer code in buzz the buzzer rings constantly. Can anyone advise where I went wrong?
And also, how do I get this to NOT trigger my ATO Timeout?
Should I be using analogWrite or digitalWrite? I have an analog RA (not PWM).
// Buzzer if temp is too high or low, or waterlevel 1 is too high or too low.
if ( ReefAngel.Params.Temp[T1_PROBE] < 700 || ReefAngel.Params.Temp[T1_PROBE] > 85 || ReefAngel.WaterLevel.GetLevel(1) > 135 || ReefAngel.WaterLevel.GetLevel(1) < 70)
pinMode(lowATOPin,OUTPUT);
digitalWrite(lowATOPin,HIGH);
digitalWrite(lowATOPin,LOW);
Re: Help with Buzzer code
Cause you're checking for temperature above 8.5 degreess :)
DigitalWrite I think. The Ato ports are pwm
And I think the WL ATO bug is triggering the timeout not this
One lat thing. I believe the WL tops out somewhere maybe 120. Have you tested to see if it goes that high? Maybe we set it to 200. I dont remember
Smotz
Post by Smotz »
lnevo wrote:Cause you're checking for temperature above 8.5 degreess :)
I accidentally reported this post :lol:
Oh my god..the little things. Always look at syntax..
This represented about 2 hours of my life. Thank you.
Yeah didnt help that I added a fix for StandardHeater that let you use two digits :)
