More ATO help needed
Smotz
Post by Smotz »
I am having constant ATO timeouts
This does not seem to be working for me: ReefAngel.WaterLevelATO(1,Topoff,15,85,95);
Translated to me, this means if waterlevel(1) hits 85% turn on turn on (Topoff) until 95% for a max of 15 seconds.
I put the below code in instead. Any thoughts? Why isn't it working?
// Main Top Off
// ReefAngel.WaterLevelATO(1,Topoff,15,85,95);
// just to be safe if the water level gets to 135 or greater, turn off the topoff.
if ( ReefAngel.WaterLevel.GetLevel(1) <=85 ) ReefAngel.Reelay.On (TopOff);
if ( ReefAngel.WaterLevel.GetLevel(1) <=95 ) ReefAngel.Reelay.Off (TopOff);
if ( ReefAngel.WaterLevel.GetLevel(1) >= 135 ) ReefAngel.Relay.Off (Override);
// End Main Top Off
Re: More ATO help needed
There's a fix in dev. I haven't tested, but it's two lines if you want to just apply it to the current code. Take a look at dev branch on github. Not home so sorry for the bad instructions. Can give you more detail later, but yes having same issue.
Smotz
Post by Smotz »
Ok, no problem. Thanks for the reply. I'll just use the alternate code for now.
I am moving modules from one RA to another (upgrading my tank) and am running in to a slew of issues.
Smotz
Post by Smotz »
lnevo wrote:There's a fix in dev. I haven't tested, but it's two lines if you want to just apply it to the current code. Take a look at dev branch on github. Not home so sorry for the bad instructions. Can give you more detail later, but yes having same issue.
A friendly reminder for a bit more details - I am having a problem finding the fix in DEV.
Smotz
Post by Smotz »
Thank you, as always!
I put the test code on and my controller should try and refill this evening. Will keep you posted...
re76
Post by re76 »
Just as a heads up it looks like you have a typo in there. Reelay != Relay. :)
Smotz
Post by Smotz »
re76 wrote:Just as a heads up it looks like you have a typo in there. Reelay != Relay. :)
holy crap!
Worked great tonight.
Smotz
Post by Smotz »
Looks good for me too. Monitoring..
Smotz
Post by Smotz »
Still getting random ATO timeouts - not as often but still happening for no apparent reason.
Yep, timed out on me tonight as well.
Smotz
Post by Smotz »
Lots of timing out. What are people doing as a band-aid?
I am trying to upgrade my IDE so can't upload new code for a bit.
My ATO would only time out in the first few minutes and it's timed to only work starting at 8pm. So for the first few minutes I clear the timeout.
If you're ok breaking your ato up into a timed even we can control clearing the timeout..you'll still have protection but basically we have a known starting point so we wouldn't clear outside that window.
Smotz
Post by Smotz »
lnevo wrote:I am trying to upgrade my IDE so can't upload new code for a bit.
Think it'll be better to go this route?
