Relay box - ports flickering
PostPosted: Mon Aug 29, 2016 6:15 am
Hi Roberto,
Ok, this is strange, so I happen to be around all day Sat & Sun and noticed that the relay flickering on and off only happens when the the dimming occurs at higher levels. Meaning it seems like there is like a threshold at when the dimming is occurring causing this issue. At low levels during the ramping up and ramping down, this doesn't happen.
Any ideas?
PostPosted: Mon Aug 29, 2016 8:33 am
Good troubleshooting.
What version of dimming module do you have?
You may need to open the case and it will be written on the pcb board.
PostPosted: Mon Aug 29, 2016 6:31 pm
rimai wrote:Good troubleshooting.
Version 1.2
PostPosted: Fri Sep 02, 2016 4:24 am
Any input / help Roberto?
PostPosted: Fri Sep 02, 2016 9:27 am
Are you using this with the RANet?
PostPosted: Fri Sep 02, 2016 12:09 pm
nope
PostPosted: Fri Sep 02, 2016 6:04 pm
Can you post the code you have loaded?
Is it a regular wizard code?
PostPosted: Mon Sep 05, 2016 2:11 pm
rimai wrote:Can you post the code you have loaded?
Strange part is that it hasn't changed.
    ReefAngel.PHMin=560;
    ReefAngel.PHMax=794;
    InternalMemory.DCPumpThreshold_write(15);
    ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
    ReefAngel.WaterChangePorts = Port2Bit | Port3Bit | Port4Bit | Port5Bit | Port6Bit | Port8Bit;
    ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit | Port4Bit | Port7Bit | Port8Bit;
    // Use T3 probe as temperature and overheat functions
    InternalMemory.OverheatTemp_write( 835 );
    ReefAngel.DCPump.FeedingSpeed=16;
    ReefAngel.Relay.On( Port2 ); //Dimming Module
    ReefAngel.Relay.On( Port4 ); //Skimmer
    ReefAngel.Relay.On( Port8 ); //Return
    ReefAngel.StandardHeater( Port1,780,785 );
    ReefAngel.StandardLights( Port3,14,00,21,30 ); // T5
    ReefAngel.StandardLights( Port7,0,30,10,30 ); // Fuge Lamp
    ReefAngel.StandardLights( Port6,15,15,20,45 ); //RW20
    ////// Light Schedule Below
          //Set Channel 0 LED RED
          if (PWMSlope(13,15,22,45,5,85,120,5)<=6)
            ReefAngel.PWM.SetChannel( 0, 0);
            ReefAngel.PWM.SetChannel( 3, 0);
            ReefAngel.PWM.SetChannel( 0, PWMSlope(13,15,22,45,5,85,120,5) );
            ReefAngel.PWM.SetChannel( 3, PWMSlope(13,15,22,45,5,85,120,5) );
          //Set Channel 1 LED WHITE
          if (PWMSlope(13,30,22,30,5,80,120,5)<=6)
            ReefAngel.PWM.SetChannel( 1, 0);
            ReefAngel.PWM.SetChannel( 4, 0);
            ReefAngel.PWM.SetChannel( 1, PWMSlope(13,30,22,30,5,80,120,5) );
            ReefAngel.PWM.SetChannel( 4, PWMSlope(13,30,22,30,5,80,120,5) );
          //Set Channel 2 LED BLUE
          if (PWMSlope(13,0,23,0,5,100,120,5)<=6)
            ReefAngel.PWM.SetChannel( 2,0);
            ReefAngel.PWM.SetChannel( 5,0);
            ReefAngel.PWM.SetChannel( 2, PWMSlope(13,0,23,0,5,100,120,5) );
            ReefAngel.PWM.SetChannel( 5, PWMSlope(13,0,23,0,5,100,120,5) );
   ////// End of Light Schedule
  //Setting Jebao Pump Wave Patterns
 if (InternalMemory.DCPumpMode_read()==11) //if custom mode on portal
  if (hour()>=12 && hour()<13 ) // Morning mode between 12pm and 2pm
    ReefAngel.DCPump.SetMode( TidalSwell,80,25 );
     else if (hour()>=13 && hour()<16) // Day mode between 2pm and 4pm
    ReefAngel.DCPump.SetMode( ShortPulse,80,25 );
     else if (hour()>=16 && hour()<20) // Day mode between 4pm and 8pm
    ReefAngel.DCPump.SetMode( ShortPulse,100,25 );
     else if (hour()>=20 && hour()<21) // Evening mode between 8pm and 9pm
     else if (hour()>=21 && hour()<23) //Calming beween 9pm and 11pm
    ReefAngel.DCPump.SetMode( Lagoon,75,20 );
    ReefAngel.DCPump.SetMode( Lagoon,40,20 );  // Night Mode between 11pm and l2pm
 else ReefAngel.DCPump.UseMemory = true; //if it's not on custom, use portal program
    ReefAngel.DCPump.ActinicChannel = Sync; //use None when inactivated
    ReefAngel.Portal( "civics14" );
PostPosted: Mon Sep 05, 2016 6:37 pm
Are you using a hub?
Is the dimming expansion the only expansion module?
PostPosted: Tue Sep 06, 2016 1:02 pm
rimai wrote:Are you using a hub?
No hub, just the dimming expansion as the only expansion module
Return to Standard
Users browsing this forum: No registered users and 6 guests
