Return pump interfering with float switch locking up RA
Re: Return pump interfering with float switch locking up RA
And buying more modules right now is not going to happen. Just had to replace 2 failed modules and added one new one one that seems to have made my ATO not function. I guess tomorrow I will start unplugging stuff to test the bus theory.I sure hope it doesn't prove out.
i just hooked up my new float switches today. will see if its any better in a day or two
I add a Ferrit bead to my pump cord and ballast cord and problem Has stopped. I'll update in a day.
Still had issue. Moved bead to ATO lead. It stopped instantly. We'll see.
Yes I am very happy. Hasn't acted up in 24hrs. Thanks for your help.I had to order another Ferrit bead because I borrowed one found my wifi subwoofer. i ordered 5 and plan to put one on every cord that enters the water. At $2 apiece cheap insurance.
my RA hasn't locked up since replacing float switches, must have been them slowing failing
