Post an issue on the github to request this.
https://github.com/reefangel/U-App-2.0
If you want to look through the code and help us implement, it would be awesome
The entire UApp is built in HTML5 and javascript.
internal web page no longer working?
Re: internal web page no longer working?
Cool, thx. Will do.rimai wrote:Post an issue on the github to request this.
So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
exactly. apparently if you use authentication on the internal web page, it won't work.saf1 wrote:So...dumb question. This is the built in portal with the WiFi attachment? Never could get that to work properly so the portal here is what I use.
