Trouble Uploading
pisanoal1
Trouble Uploading
Post by pisanoal1 »
So I upgraded tanks, and I went to upload new code to include a dimming module for my lighting. However, I am unable to upload code to my RA. Ive had it for a while and have uploaded code over a dozen times. I did have to buy a new USB to TTL cable because my cat chewed my last one. I get an Error Uploading message, that says connection timed out. I was able to program the Wifi module with this cable. Any ideas?
I should add I got the cable off amazon for shipping speed because I cant run my lights without the dimming module because I bought fans that need to be controlled. It appears to be the same cable.
Re: Trouble Uploading
Check if you have the correct board selected on Tools-Boards
pisanoal1
Post by pisanoal1 »
I checked that. I also reinstalled the cable driver. I ordered another cable from the RA website but I don't have much faith in that
Does the controller reboot a few seconds after you hit upload?
pisanoal1
Post by pisanoal1 »
No it does not
