used reef angel
used reef angel
what should i do when i get it is there a way to reset the unit to make it like a new one ? it has the wifi unit with it do i need to do anything special with it thanks in advance
Re: used reef angel
Not sure on the wifi module. For the RA itself, you'll just use the Wizard to start a new code and when you upload it, it will be reset to your specifications Pretty simple, you can start early and download the app now.
Re: used reef angel
were do i get the app from ? and does it work with a mac
Re: used reef angel
ok i found the app what code do i want to download
Re: used reef angel
Go under the tools menu and use the Wizard to generate code.
Is it a Plus or a Standard? The latest software doesn't work with a standard.
Re: used reef angel
how do i know if its a plus ?
Re: used reef angel
ask the seller. You'll need the plus to really get good use out of it. It's easy enough to upgrade if you need to.
Re: used reef angel
Re: used reef angel
no plus on the outside so i need to take it apart and look for what ?
Re: used reef angel
Post a picture of the front of the board.
Re: used reef angel
There's your answer.
