wifi help
kga943
wifi help
Post by kga943 »
ok i have the wifi unit hooked up to my mac and i can't tell if its set up heres a picture why does it say false instead of true ?then after i get this how do i upload the wifi test arduinoImage
kga943
Re: wifi help
Post by kga943 »
anyone ?
Re: wifi help
The ssid and password is case sensitive.
Make sure it is the same case.
Also, try changing the password to not have a question mark. I'm not sure if that is causing any issue.
kga943
Re: wifi help
Post by kga943 »
so all the things that say false should say true ?
Re: wifi help
yes
kga943
Re: wifi help
Post by kga943 »
ok all say true now so i hook it up to the reef angel and i get this now at ?
Re: wifi help
That means you are all set.
You are reaching to the internal web server and you are ready to start using any of the phone apps :)
kga943
Re: wifi help
Post by kga943 »
but when i try and connect with my phone it just says connecting but it never does
