'lo all.
I have a multi water level sensor. Today I added a 2nd tube to read from but the portal is not showing readings from it. everything else on the portal is working fine - the last connect time is accurate, and I can control all of my ports.
The 2nd water level sensor does show in my android app.
equally important, notifications have stopped working since it looks like 12/22/16
Any thoughts?
Portal not showing additional water level sensor
Re: Portal not showing additional water level sensor
Nevermind. Needed to run the macro.
