Explain internal memory
PostPosted: Thu May 18, 2017 6:51 pm
rimai wrote:The controller will show whatever is in the memory. If you hard coded, I mentioned above that those settings will be ignored.
It will use whatever your code instructed it to do.
If you use internal memory settings, it will use those settings and they should match to what the portal and app settings show too, because they are going to pull the settings from the RA memory.
I read your post above, just didn't follow how that related to what is displayed on the controller itself. I've got it now. Thanks!
Previous
Return to Standard
