Litany of strange goings on...
skehole
Re: Litany of strange goings on...
Post by skehole »
Why are my relays on the portal not reflecting the relays on the app?
GugsJr
Post by GugsJr »
The labels? Or you mean you can't access the relays from the portal.
If it's the labels you have to change the names in the portal and download them to the app.
If you can't access the relays from the portals. Probably means your port forwarding isn't set up correctly.
skehole
Post by skehole »
GugsJr wrote:The labels? Or you mean you can't access the relays from the portal.
if you compare the two pictures I posted of my app screen shot and the portal photo, the auto, on , and off do not correlate from one to the other.
skehole
Post by skehole »
And honestly, I don't care too much as I use the U-App exclusively but just wanting things to work either way just in case
GugsJr
Post by GugsJr »
Oh I see that, honestly I'm not sure. Roberto probably would be the person you need help from.
It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
skehole
Post by skehole »
rimai wrote:It says the last time you sent data to the portal was 3/23/2017, 12:33:07 PM
That's strange seeing as how I posted the screenshot on the 24th. What would cause that to happen? Port forwarding is working on my U-App
Did you change code around that time?
skehole
Post by skehole »
rimai wrote:Did you change code around that time?
Yes I switched to internal memory coding. The code should be listed above. Also noticing that my graphs will not allow me to go beyond 1 or 12 hour time periods
It is because your last data was 03/23 and it only keeps for 7 days.
Tomorrow you won't have data.
I think it is because of the space on the ddns.
Try removing that space.
skehole
Post by skehole »
rimai wrote:I think it is because of the space on the ddns.
Can you show me where you're talking about? I assume it's at the end, but I'm not sure what space you're talking about.
Also, this was generated via the wizard and was not altered in any way.
Yes, the space on your ddns line.
 ReefAngel.DDNS( "fish tank" );
Use fishtank without a space.
HTTP protocol doesn't understand spaces.
skehole
Post by skehole »
rimai wrote:Yes, the space on your ddns line.
Gotcha. Thanks I will try when I get back in town.
skehole
Post by skehole »
That appears to have done it. Thanks!
