Web wizard
PostPosted: Fri May 05, 2017 3:11 pm
I have switched over to using the web wizard, but i am having problems. When trying to generate a code, once i have programmed everything, i go to hit generate and all it gives me is a blank code. If i try to upload this, the controller has a blacked out screen.
The reason for me using web wizard instead or arduino, is that i recently bought the cloud wifi attachment, and arduino is not showing it as an option while using the arduino wizard. Can anybody help with getting my cloud wifi to work?
PostPosted: Fri May 05, 2017 3:15 pm
Try in another browser and let us know if you still have problems.
PostPosted: Fri May 05, 2017 7:39 pm
I tried it in Firefox, Chrome, and microsoft edge, and still get the same result. This is the code it generates:
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
PostPosted: Fri May 05, 2017 7:44 pm
Whats weird is that if I change all 8 ports to not used, it will than generate a normal looking code:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
PostPosted: Fri May 05, 2017 10:24 pm
There may be a bug somewhere.
Can you try one port at a time and report which one is the one failing?
PostPosted: Fri May 05, 2017 10:59 pm
ok, so both ports 3 & 4 the ones causing the code not to generate. they were both time schedule. once I changed the function to always on, the code generated. But once I go to upload the code, it takes a long time, than gives an upload timeout error.
PostPosted: Fri May 05, 2017 11:09 pm
It works for me if I set to time schedule.
What hours were you using?
PostPosted: Fri May 05, 2017 11:15 pm
port 3, 12:00pm -9:00pm and port 4, 1:00pm - 9:00pm
This code below is the one I have always used and works great, I just want to add my new cloud wifi. Is there a way I can just add it into the sketch?
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardLights( Port2,12,0,21,0 );
ReefAngel.StandardLights( Port3,13,0,20,0 );
ReefAngel.Relay.DelayedOn( Port4,2 );
ReefAngel.Relay.DelayedOn( Port6,4 );
PostPosted: Fri May 05, 2017 11:24 pm
Yeah.
You need to add this:
Just above ShowInterface()
Then, generate a code and copy the 3 bottom lines too.
They look like this:
// RA_STRING1=U2FsdGVkX1/SYcbxqia+Ctm9luLvQ1ZrEDcg2DDgO3k=
// RA_STRING2=U2FsdGVkX191TYz62vRRqpOWczR5eL/HX1DHEXNFSvY=
// RA_STRING3=testing2
Try that and let me know if you have problems compiling.
I was able to replicate the problem.
Thanks for reporting and troubleshooting:)
The timeout error is another issue.
Check if you are using the correct COM port.
PostPosted: Fri May 05, 2017 11:58 pm
Ok, I think I fixed the bug.
Can you try and report back?
Next
Return to Standard
