Web wizard
Posted: Fri May 05, 2017 3:11 pm
by Reeflife916
I have switched over to using the web wizard, but i am having problems. When trying to generate a code, once i have programmed everything, i go to hit generate and all it gives me is a blank code. If i try to upload this, the controller has a blacked out screen.
The reason for me using web wizard instead or arduino, is that i recently bought the cloud wifi attachment, and arduino is not showing it as an option while using the arduino wizard. Can anybody help with getting my cloud wifi to work?
Re: Web wizard
Posted: Fri May 05, 2017 3:15 pm
Try in another browser and let us know if you still have problems.
Re: Web wizard
Posted: Fri May 05, 2017 7:39 pm
by Reeflife916
I tried it in Firefox, Chrome, and microsoft edge, and still get the same result. This is the code it generates:
void setup() {
// put your setup code here, to run once:
void loop() {
// put your main code here, to run repeatedly:
Re: Web wizard
Posted: Fri May 05, 2017 7:44 pm
by Reeflife916
Whats weird is that if I change all 8 ports to not used, it will than generate a normal looking code:
ReefAngel.FeedingModePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.WaterChangePorts = Port4Bit | Port5Bit | Port6Bit;
ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit | Port3Bit;
ReefAngel.LightsOnPorts = Port2Bit | Port3Bit;
ReefAngel.CloudPortal();
// RA_STRING1=null
// RA_STRING2=null
// RA_STRING3=null
Re: Web wizard
Posted: Fri May 05, 2017 10:24 pm
There may be a bug somewhere.
Can you try one port at a time and report which one is the one failing?
Re: Web wizard
Posted: Fri May 05, 2017 10:59 pm
by Reeflife916
ok, so both ports 3 & 4 the ones causing the code not to generate. they were both time schedule. once I changed the function to always on, the code generated. But once I go to upload the code, it takes a long time, than gives an upload timeout error.
Re: Web wizard
Posted: Fri May 05, 2017 11:09 pm
It works for me if I set to time schedule.
What hours were you using?
Re: Web wizard
Posted: Fri May 05, 2017 11:15 pm
by Reeflife916
port 3, 12:00pm -9:00pm and port 4, 1:00pm - 9:00pm
This code below is the one I have always used and works great, I just want to add my new cloud wifi. Is there a way I can just add it into the sketch?
ReefAngel.Relay.On( Port5 );
ReefAngel.StandardHeater( Port1,780,790 );
ReefAngel.StandardLights( Port2,12,0,21,0 );
ReefAngel.StandardLights( Port3,13,0,20,0 );
ReefAngel.Relay.DelayedOn( Port4,2 );
ReefAngel.Relay.DelayedOn( Port6,4 );
Re: Web wizard
Posted: Fri May 05, 2017 11:24 pm
Yeah.
You need to add this:
Just above ShowInterface()
Then, generate a code and copy the 3 bottom lines too.
They look like this:
// RA_STRING1=U2FsdGVkX1/SYcbxqia+Ctm9luLvQ1ZrEDcg2DDgO3k=
// RA_STRING2=U2FsdGVkX191TYz62vRRqpOWczR5eL/HX1DHEXNFSvY=
// RA_STRING3=testing2
Try that and let me know if you have problems compiling.
I was able to replicate the problem.
Thanks for reporting and troubleshooting:)
The timeout error is another issue.
Check if you are using the correct COM port.
Re: Web wizard
Posted: Fri May 05, 2017 11:58 pm
Ok, I think I fixed the bug.
Can you try and report back?
Re: Web wizard
Posted: Sat May 06, 2017 12:00 am
by Reeflife916
Ok, so i got the web wizard to work by figuring out the correct com port, but the wifi still is not connecting to network. After i upload code to cloud wifi should the indicator light blue? Mine is a slow blink green
Re: Web wizard
Posted: Sat May 06, 2017 12:20 am
by Reeflife916
I am happy to report that it now generates with the time schedules. Also, I have my cloud wifi lit blue now, but for some reason I cannot see it in the portal or in the uapp
Re: Web wizard
Posted: Sat May 06, 2017 8:10 am
Can you send me the code you uploaded for both RA and Cloud wifi?
