Temp probs reading 00.0
PostPosted: Wed Jun 07, 2017 2:00 pm
I have 3 temp probes and all three all of a sudden are reading 00.0 I reset the controller with no luck. What would cause all 3 to read 00.0?
PostPosted: Wed Jun 07, 2017 2:17 pm
Just tried reloading program and still no luck.
PostPosted: Thu Jun 08, 2017 7:54 pm
If you got them on eBay like I did, the pins were reversed on mine.
PostPosted: Fri Jun 09, 2017 5:14 am
No I've had these for awhile and they all worked then bam all three just read zero
PostPosted: Sat Jun 10, 2017 9:53 am
Check for water damage and try one at a time.
Everytime you remove or insert a probe, make sure to power cycle to get the controller to recognize it.
It only scans for new probes on reboot.
PostPosted: Sat Jun 10, 2017 10:09 am
Ok that did the trick thanks for the help
Return to Standard
