waterlevel ato
PostPosted: Mon Jul 31, 2017 5:32 am
Yeah but it's something other topping is not staying set, causing it to go into a constant restarting loop.
So I added a Serial.println(topping); whenever StartTopping or StopTopping are called.
inline void StartTopping() { topping = true; Serial.println(topping);}
inline void StopTopping() { topping = false; Serial.println(topping);}
Starting: 161841
0
0
0
1
Starting: 162052
0
0
0
1
Starting: 162264
0
0
0
1
Starting: 162413
0
0
0
1
The Starting statement is the millis right after we call StartTopping
if ( WaterLevel.GetLevel(Channel) < LowLevel && ( !WLATO.IsTopping()) && bitRead(AlertFlags,ATO
WLATO.Timer = millis();
WLATO.StartTopping();
Relay.On(ATORelay);
Serial.print("Starting: ");
Serial.println(WLATO.Timer);
PostPosted: Mon Jul 31, 2017 5:58 am
Ok, I'm the one clearing topping... ok digging deeper.
PostPosted: Mon Jul 31, 2017 6:29 am
Ok so there's definitely an opportunity for a wrap in the unsigned long that coudl cause the timeout to fire prematureley...
if ( (millis()-WLATO.Timer > TimeTimeout) && (WLATO.IsTopping() )
If millis does wrap (which to does, but supposedly every 50 days) then the current time will be less than the timer was set for and then when we subtract it will wrap and be greater than TimeTimeout. But it should be rare and it isn't, unless it's wrapping sooner then expected.
Previous
Return to Standard
