Unstable ReefAngel
PostPosted: Sun Jul 16, 2017 12:40 pm
rimai wrote:http://forum.reefangel.com/viewtopic.php?f=3&t=4601
This one was done not so long ago when portal ip was changed. Since then it changed or not? Or should I do the same update?
PostPosted: Mon Jul 17, 2017 10:50 am
Same one.
When did this start happening?
Any change on code or router?
Can you check for any water damage?
PostPosted: Mon Jul 17, 2017 11:51 am
It started after recent update of the code in RA (earlier it was the same but not so often, values changed to zero once 5 minutes or so). In code there were changes just for ph exp values (even with the old code same happens).
Router has not been changed. Also cannot find any water damage.
PostPosted: Mon Aug 28, 2017 1:24 pm
Done that few times. Tried experimenting why this is happening. And seems that the wire from RA to Wifi is causing this. If I'm finding some position - everything is working fine. @rimai how can I get replacement wire?
PostPosted: Mon Aug 28, 2017 2:30 pm
Send me a PM.
Previous
Return to Standard
