switching from reef angel plus to reef angel
PostPosted: Fri Jul 28, 2017 6:24 pm
need to do this to trouble shoot my RA. but im getting that the final code is too large... what do i need to trim to make this work on my reef angel
    ReefAngel.AddStandardMenu();  // Add Standard Menu
    ReefAngel.FeedingModePorts = Port1Bit; //| Port2Bit| Port5Bit| Port8Bit;;
    ReefAngel.WaterChangePorts = Port1Bit | Port2Bit| Port3Bit | Port4Bit|| Port5Bit| Port7Bit;
    ReefAngel.LightsOnPorts = Port5Bit;
    ReefAngel.OverheatShutoffPorts = Port1Bit | Port2Bit| Port3Bit | Port4Bit| Port5Bit| Port7Bit;
      ReefAngel.Relay.On(Port1);                                     // Return Pump Port 1      Port1
      ReefAngel.SingleATO( true,Port2,600,0 );                        // ATO         Port 2
      ReefAngel.StandardHeater( Port3,780,795 );                    // Heater       Port 3
      ReefAngel.StandardHeater( Port4,780,790 );                   //  Heater       Port 4
      //ReefAngel.Relay.On( Port5 );                                   //Cal Rx pump        Port 5
      ReefAngel.Relay.Set(Port6,ReefAngel.Relay.Status(Port1));   // Skimmer        Port 6
      ReefAngel.Relay.On( Port7 );                                   //Return       Port 7
      ReefAngel.CO2Control(Port8,730,735);                           //Regulator    Port 8  (PhLow,PhHigh)
//ReefAngel.StandardLights( Port5,14,0,20,0 );                      //
//      //ReefAngel.Relay.Set(Port5,ReefAngel.Relay.Status(Port7));   // Cal Rx pump     Port 5
//  ReefAngel.Relay.Set(Port1,ReefAngel.Relay.Status(Port7))
 //ReefAngel.Relay.On (Port5);                                 // Fuge Light     Port 5   ----  Bsmt De-humidier
//ReefAngel.DosingPumpRepeat( Port7,0,720,14 );                     //Alk   15.4 mls
//ReefAngel.DosingPumpRepeat( Port8,5,720,14 );
//for 36 mls
//      ReefAngel.DosingPumpRepeat( Port7,0,240,11 );                     //Alk
//      ReefAngel.DosingPumpRepeat( Port8,5,240,11 );
 //box 2 (Box1_Portxx) Expansion Box
//!flips the status of the port for conditional statements
PostPosted: Sat Jul 29, 2017 5:30 am
first thing is revert back to version 1.0.4 of the libraries. anything later is too big for the standard ra (i think that's the version).
give that a try first.
you may also have to remove the co2control function because it may not be in the libraries that far back (uncertain, have to check).
PostPosted: Sun Jul 30, 2017 5:18 pm
It's in there.
Return to Standard
