Page 4 of 4
Re: Reef Angel Star Controller
Posted: Sat Nov 11, 2017 1:09 pm
by Sacohen
Ok.
And the RANet and Relay work fine with it too?
Posted: Sat Nov 11, 2017 1:17 pm
RANet works fine, but the main relay box will need one of the old relay modules, since RA* only has expansion ports.
Posted: Sat Nov 11, 2017 1:24 pm
by Sacohen
rimai wrote:RANet works fine, but the main relay box will need one of the old relay modules, since RA* only has expansion ports.
The $50 ones that you don't have in stock yet?
That you are talking about here...
rimai wrote:
In order to use your main relay box as expansion, you need one of the old relay expansion modules, which we are in the process of getting them built to sell in the web store.
They cost $50.
We only have one of them in stock before we get the next batch.
Posted: Sat Nov 11, 2017 1:54 pm
Yes, those ones. I have a few on hand
Posted: Sat Nov 11, 2017 3:08 pm
by Sacohen
Ok.
I have to get the money together.
Posted: Mon Nov 13, 2017 10:35 am
by Naptalene
Me too lol
Sent from my iPhone using Tapatalk Pro
Posted: Tue Nov 14, 2017 4:19 pm
by tkeracer619
rimai wrote:If you use the webwizard, simply add this to setup():
Cool, does it just use the extra inputs?
Posted: Tue Nov 14, 2017 7:11 pm
No, you have to splice more probes in parallel to the existing ones or create your harness that has more connectors or get something like this from amazon or any other electronic store.
They are y-split cables for computer fans.
- y split.jpg (12.41 KiB) Viewed 12718 times
https://www.amazon.com/dp/B01DRE2UAI/re ... 0599452956
Posted: Mon Nov 27, 2017 8:24 pm
by tkeracer619
How far away can the expansion relay sockets be from the head unit?
Here is what I would like to do...
600gal display needs a relay box and vortech control(already have) ~35 ft from controller.
Sump room needs...
2 to 3 relay boxes
11 temp probes
Orp (already have)
Sg (already have)
PHx2
I already have an expansion module. Do I need anything else to make this work?
Would like to flush a large touch screen pc or tablet into the wall to use for continuous portal display. How customizable is the portal these days?
I was going to go with a plc to control all my lights and use my existing RA+ for monitoring but like the idea of a hardwire so am considering making the jump.
What issues do you see?
Posted: Mon Nov 27, 2017 8:51 pm
I think your best bet is to use the RANet.
It's an RF wireless option that allows you to control the relay expansion box without the USB connection.
Simply power it and it will pick up signal from the head unit.
http://forum.reefangel.com/viewtopic.php?f=3&t=4763
Posted: Mon Nov 27, 2017 9:27 pm
by tkeracer619
What about the vortech rf control at the display? Seems like I would already have to run a cable up there.
Interesting thing about RANet... I work with one of the people who came up with zigbee.
Posted: Sun Dec 10, 2017 10:58 pm
by tkeracer619
Any thoughts on this? What would it take to get the Vortech RF module 30 or so feet from the head unit?
Posted: Sun Dec 10, 2017 11:26 pm
Not sure how to do this. We are not even selling RF modules anymore.
They are very closed about their protocol and no help was ever provided. So, we decided not to carry those anymore.
Posted: Wed Dec 13, 2017 9:17 am
by tkeracer619
I still have one so hopefully it will work. Since I already have a plus I may use it to develop my new setup and switch over to the Star once I am ready and confident I have it all working. At that point I can just use the Plus for the display to control the lighting and the vortechs. I like the idea of having a hardwired controller. The Wifi module was always flaky for me. Though, that could have been routing issues, i've since moved on to Ubiquiti network hardware which was a massive upgrade in stability.
Posted: Thu Apr 19, 2018 1:40 pm
by akkord64
Can the eagle files be uploaded to the website for the star as well as the other missing modules? Looking forward to reviewing them. Thanks!
Posted: Thu Apr 19, 2018 8:59 pm
tkeracer619 wrote:I still have one so hopefully it will work. Since I already have a plus I may use it to develop my new setup and switch over to the Star once I am ready and confident I have it all working. At that point I can just use the Plus for the display to control the lighting and the vortechs. I like the idea of having a hardwired controller. The Wifi module was always flaky for me. Though, that could have been routing issues, i've since moved on to Ubiquiti network hardware which was a massive upgrade in stability.
The RF module still works with my MP40WQD. One thing to note though is that for the QD I had to sync first with the older driver then switch the wireless module back to the QD. The sync software did not trigger anything on the newer driver. Once it was sync'd though, it works great.
Posted: Wed May 09, 2018 10:32 pm
by tkeracer619
lnevo wrote:tkeracer619 wrote:I still have one so hopefully it will work. Since I already have a plus I may use it to develop my new setup and switch over to the Star once I am ready and confident I have it all working. At that point I can just use the Plus for the display to control the lighting and the vortechs. I like the idea of having a hardwired controller. The Wifi module was always flaky for me. Though, that could have been routing issues, i've since moved on to Ubiquiti network hardware which was a massive upgrade in stability.
Good tip!
