Reef Angel Star Controller
PostPosted: Fri Sep 08, 2017 2:18 pm
also the touch screen works intermittently, is there some bugs with this thing or am I doing something wrong?
PostPosted: Fri Sep 08, 2017 3:08 pm
Did you install the plugin?
Does it show plugin connected?
How did you loaded your code if there are no com ports listed?
Did you reset the password for the forum? Your username was created way before the cloud server came online. There is a note stating that you must reset or it won't authenticate you
PostPosted: Fri Sep 08, 2017 3:54 pm
rimai wrote:Did you install the plugin?
I did install the plug in. It shows connected. I had com 3 once, now I don't. Cant get it to come back. I did reset the password. I'm lost with this star and thinking about hooking my plus back up. My screen is intermittent, sometimes won't even turn on when touched. My ports issuing the time on/off programming don't turn off, ever. I bought the TL wifi adapter, set it up as client and hooked a LAN cable between the two. Not sure what's wrong but frustrated. Any help, please and thank you
PostPosted: Fri Sep 08, 2017 4:40 pm
Does the com port show up in your device manager?
PostPosted: Sun Sep 10, 2017 5:53 am
just wondering... Does RA* have the r99 xml stream?
I use it today to be able to send push notifications to my phone
Rafa
PostPosted: Sun Sep 10, 2017 6:57 am
rrodriguess wrote:just wondering... Does RA* have the r99 xml stream?
Rafa
yes it does.
PostPosted: Sun Sep 10, 2017 7:31 am
Roberto, I moved the star over to my primary account. All is working fine. Will the Main Relay Box ever disappear from the portal?
PostPosted: Sun Sep 10, 2017 8:28 am
cool. It may but I need to change the backend
PostPosted: Mon Sep 11, 2017 5:23 am
I have noticed that if the network connection is not available, there is a delay in the device responding to touchscreen touches and updating the display. I found this out when I was working on my firewall rules and a separate dhcp server. I haven't looked into it more closely, just mostly sharing with everyone.
PostPosted: Mon Sep 11, 2017 8:20 am
How long was this delay?
Return to Standard
Users browsing this forum: Google [Bot], Majestic-12 [Bot] and 2 guests
