Reef Angel plus upgrade
Posted: Sat Aug 05, 2017 6:11 am
by Rezn8
Okay , so after huge learning curve , just got a reef Angel plus upgrade board . So I can use wifi after I was sold a normal as a plus.
Screen doesn't work on it when I change boards.
Is board faulty ?
Re: Reef Angel plus upgrade
Posted: Sat Aug 05, 2017 6:41 am
by Rezn8
Okay , in the programming - wow , steep learning curve.
Posted: Sat Aug 05, 2017 8:07 am
by Rezn8
Sorted - understand the programming as well now , much easier.
Just need to sort out portal 100%
Posted: Sat Aug 05, 2017 8:40 am
You may need to add a line of code at least one time to tell the controller which screen you are using.
http://forum.reefangel.com/viewtopic.php?f=2&t=3111
It only needs to be once and then the controller will always know which screen it is as it stores in the internal memory.
