Relay PWM? Version 8.0
PostPosted: Sat Sep 23, 2017 8:40 pm
by n1ng
Hi Everyone,
I just bought a used RA. I want to try to dim my kessil 160we. I cracked open the relay looking for jumpers but didn't find any. The board is labeled version 8.0 is it PWM? And 0-12v? I'm guessing that I need analog?
Is there a way to diy could convert to analog?
Norm
Re: Relay PWM? Version 8.0
PostPosted: Sat Sep 23, 2017 9:25 pm
Can you post a photo of the inside?
PostPosted: Sun Sep 24, 2017 11:01 am
by n1ng
Here you go.
Thanks Roberto!
PostPosted: Sun Sep 24, 2017 11:52 am
You will have to populate R1/C1 and R2/C2 with 10K/10u components.
PostPosted: Sun Sep 24, 2017 12:52 pm
by n1ng
Thanks Roberto. Is this the low pass filter (capacitor and resistor)? I'm guessing I can make the circuit and connect it to the leads outside the relay box?
15851255626_49ae83a2f4_o (1).png (11.84 KiB) Viewed 2073 times
Also there seem to be two pads on R1/C1 and R2/C2 which ones would I use? I highlighted my guesses :?
Sorry for all the questions, I have no background in electrical circuitry.
Norm
PostPosted: Sun Sep 24, 2017 5:39 pm
Correct. It's the filter and you do need to have them before the amplifier.
If you do the way you mentioned outside the relay box, it won't work.
Not sure what you are asking about the pads.
Each resistor has 2 terminals and each capacitor have two terminals.
You just need to solder them on the locations shown in the board.
PostPosted: Sun Sep 24, 2017 8:03 pm
by n1ng
rimai wrote:Correct. It's the filter and you do need to have them before the amplifier.
Ahhh I think I get it. So R1, R2, C1, C2 all have two pads. So I just need to solder the resistor terminals to the pads.
So for example the capacitor for C2 would be soldered to C2 and "+" correct?
And since you mentioned an amplifier I'm guessing I have the 12v required to dim the kessil?
Norm
PostPosted: Sun Sep 24, 2017 9:14 pm
R1/C1/R2/C2 are the reference label of the component. The + is polarity of the capacitor should you want to use polarized capacitor.
PostPosted: Mon Sep 25, 2017 5:24 am
by n1ng
Thanks again. I give it a try.
PostPosted: Wed Sep 27, 2017 4:45 pm
by n1ng
All done! Just like Roberto said. Solder on the caps and resistors. Made an adapter for the relay to connect to the Kessil cable and voila! Dimming leds!
Thanks for all the help!
