USB port blocked on relay box
Posted: Thu Nov 02, 2017 9:35 am
Hi Everyone,
Excited and totally new to RA scene from Australia!
I have the RA Star which came with a relay box with Mini-USB connector. It seems that the plastic cover is mis-aligned with the port. So I can't actually plug-in the cable.
Has anyone else had this issue? If so how did you solve it?
I know that I can simply dremmel the hole bigger, but I'm worried that surface mounted USB connector will fall off unless the cut-out is helping to hold the plug in place.
Any thoughts will be greatly appreciated!
Cheers,
Ed
Cheers,
Ed
