heater not turning off
Posted: Sun Dec 10, 2017 10:45 am
now that I have reprogrammed my controller after dealing with my lights issue my heater doesn't shut off when it gets above the desired temp. ive tried setting it to all three temp probes and none of them turn the heater off. I set the code up with the internal memory. here is the code I have loaded.
ReefAngel.WaterChangePorts = Port3Bit;
ReefAngel.Relay.On( Port4 );
ReefAngel.StandardATO( Port3 );
ReefAngel.MoonLights( Box1_Port6 );
ReefAngel.PWM.Channel0PWMSlope();
ReefAngel.PWM.Channel1PWMSlope();
ReefAngel.PWM.Channel2PWMSlope();
ReefAngel.PWM.Channel3PWMSlope();
ReefAngel.PWM.Channel4PWMSlope();
ReefAngel.PWM.Channel5PWMSlope();
ReefAngel.Portal( "jjdezek" );
