WiFi help
PostPosted: Thu Jan 11, 2018 11:47 am
Here is what I’m seeing when I click the portal.
PostPosted: Thu Jan 11, 2018 11:53 am
Click on portal settings and you can set alerts.
PostPosted: Thu Jan 11, 2018 12:04 pm
This is what I get when I try get.
PostPosted: Thu Jan 11, 2018 12:53 pm
There may be a bug in the portal. Let me double check.
Your wifi address should be showing there.
PostPosted: Thu Jan 11, 2018 1:09 pm
No, I don't think there is a bug.
I think it is because you bought an old piece of equipment that needs to be updated.
You have to update it following this thread: viewtopic.php?f=3&t=4601
PostPosted: Thu Jan 11, 2018 1:11 pm
Also, make sure you did not enable the portal key on your portal settings. Better to not induce more things that can make this not work.
PostPosted: Thu Jan 11, 2018 1:16 pm
My bad.
I should have checked this before posting.
Your wifi attachment is actually working fine and updated.
The server is getting data.
It is not updating it because you probably enabled the portal key and your code doesn't have it.
Thus, it is simply disregarding it.
Make sure to not enable the portal key on your portal settings.
PostPosted: Thu Jan 11, 2018 1:34 pm
Well thank you for help everything is up and going finally.
PostPosted: Sat Jun 02, 2018 5:35 pm
Hello im back at this again going to try to get this RA+ controller hooked up to the app and the portal. I just opened the RA wifi Utility and I keep getting the **ERROR-please disconnect and reconnect the RA wifi attachment. The wifi plug in is flashing green. any ideas? I am on a MacBook Pro.
Previous
Return to Standard
Users browsing this forum: No registered users and 9 guests
