Re: WiFi help
Posted: Thu Jan 11, 2018 11:47 am
by Swampfox
Here is what I’m seeing when I click the portal.
- 682CC149-8D09-4E25-98EC-80C710EC3B43.png (741.51 KiB) Viewed 11161 times
Re: WiFi help
Posted: Thu Jan 11, 2018 11:53 am
Click on portal settings and you can set alerts.
Re: WiFi help
Posted: Thu Jan 11, 2018 12:04 pm
by Swampfox
This is what I get when I try get.
- 3BC85413-796E-4F54-B34D-1E8258D62568.png (693.7 KiB) Viewed 11159 times
Re: WiFi help
Posted: Thu Jan 11, 2018 12:53 pm
There may be a bug in the portal. Let me double check.
Your wifi address should be showing there.
Re: WiFi help
Posted: Thu Jan 11, 2018 1:09 pm
No, I don't think there is a bug.
I think it is because you bought an old piece of equipment that needs to be updated.
You have to update it following this thread:
Re: WiFi help
Posted: Thu Jan 11, 2018 1:11 pm
Also, make sure you did not enable the portal key on your portal settings. Better to not induce more things that can make this not work.
Re: WiFi help
Posted: Thu Jan 11, 2018 1:16 pm
My bad.
I should have checked this before posting.
Your wifi attachment is actually working fine and updated.
The server is getting data.
It is not updating it because you probably enabled the portal key and your code doesn't have it.
Thus, it is simply disregarding it.
Make sure to not enable the portal key on your portal settings.
Re: WiFi help
Posted: Thu Jan 11, 2018 1:34 pm
by Swampfox
Well thank you for help everything is up and going finally.
Re: WiFi help
Posted: Sat Jun 02, 2018 5:35 pm
by Swampfox
Hello im back at this again going to try to get this RA+ controller hooked up to the app and the portal. I just opened the RA wifi Utility and I keep getting the **ERROR-please disconnect and reconnect the RA wifi attachment. The wifi plug in is flashing green. any ideas? I am on a MacBook Pro.
