Baby Steps migrating from RA+ to RA* - Output Ports
PostPosted: Wed Jan 17, 2018 5:48 am
hi there
Just taking baby steps migrating from RA+ to RA*. Good oportunity to review all codes and physical installation...
One question is about the 4 output ports. I use 2 Jebao Cable Attachments with RA+, connected to my Relay Box. As far as I understand, now I should connect both Jebao Cable directely to RA*, using the 4 output ports. Is that right?
The problem is that visually the Jebao Cable connector seems not to fit in the RA* output ports (not actually tryed yet). The output ports seems more like a "RJ45" modular jack.
Can someone confirm how to use it? Am I talking nonsense?
Rafa
PostPosted: Wed Jan 17, 2018 9:11 am
Correct. You can cut and patch RJ45 or use an Ethernet cable and splice to it.
PostPosted: Wed Jan 17, 2018 9:38 am
Roberto, tks
So I can just crimp a network cable obeying the manual's specs regarding the output ports and plug it?
Rafa
PostPosted: Wed Jan 17, 2018 9:40 am
Yeap
PostPosted: Wed Jan 17, 2018 9:44 am
Awesome!!!!!
Return to Standard
