PH calibration using Ph 4 buffer
PostPosted: Sun Jan 21, 2018 7:37 am
Roberto
I own a amazonic aquarium (yes.. fresh water). With the RA+ I used to calibrate the PH using ph7 and ph4 buffer, since the aquarium has acid water (about 6.5).
How can I do the same with RA*? The Menu does not give me any option besides Ph7 and PH10.
Best regards
Rafa
PostPosted: Sun Jan 21, 2018 9:54 am
You have to edit the libraries and use the Arduino IDE.
PostPosted: Sun Jan 21, 2018 10:40 am
Roberto
Just to register, I calibrated using ph7 and ph10 buffers and after that I tested measuring ph4 buffer and worked Just Fine!!!
No need for any library edition....
Return to Standard
